Diff Question
Walked into P.E.T performance in thomastown today to watch a mates Datsun getting its Autronic tuned, im sure someones mentioned it before but they have a yellow TG sedan there with an RB30ET. And a VL rear end...
So i had to climb underneath and have a look, and what do you know its 4Link. Excuse the dodgy pics but i was wedged between a wall, the car, and i somehow had to angle my phone underneath.
Obviously un-equal length setup, but it would have to be better then the drag link/3link type. Whats the disadvantage of having such a short upper link?
Also been thinking about the setup that Gene posted as used in Camaros, corvettes etc - would it be possible to run brackets off the diff tubes [as close to the housing as possible] that boxes underneath the diff and runs up along the front and bolts near the torque tube mount?
Nick-
Nick-
the diff will roll alot earlyer in the the suspension travel.. also they wouldnt be parallel either cos the floor is to low, so it would cause it to roll earlyer againGeminiCoupe wrote: Obviously un-equal length setup, but it would have to be better then the drag link/3link type. Whats the disadvantage of having such a short upper link?
yeah u can do that, thats basicly how that rally gemini has been done as well as ZEP's gemini... only differnt is your mounting to the tubs on each side. only problem is, is if u mount the arms to the center of the car u will need a 2 piece shaft.. where as if u go to the side u can use a single as they wont get in the way of eachotherGeminiCoupe wrote: Also been thinking about the setup that Gene posted as used in Camaros, corvettes etc - would it be possible to run brackets off the diff tubes [as close to the housing as possible] that boxes underneath the diff and runs up along the front and bolts near the torque tube mount?
volvo diff just mod plated
just got my volvo rear end mod plated
Re: volvo diff just mod plated
details?jb ca18 wrote:just got my volvo rear end mod plated
volvo diff
its a 7 series volvo diff set up with a third arm similar to the mcdonalds bros setup except it has a custom mount that bolts to the old toque tube mounts intead of welding in a cross member also incorporated handbrake cable mount on yhe other side i tried to post pics but it says i havent posted enough yet
you need 10 post to post the pictures which u now have so u should be sweet.. if not sent them over to me and i can post them up for you
nismogemini@hotmail.com
what engineer did you use? im sure every one in brissy will be giving him some business
