The Price List Thread
Wfc
Post by Wfc »
The Idea i have behind this thread is that we can post information of the retailers who stock gemini parts and compare prices. I know for one that if you dont have a trade account with a parts store the prices can be anywhere from rrp to obscenly over rrp.
So if you have bought something for a gemini please help out and add it in
So if you know a shop that does good prices on gemini parts, post up part, price and contact number and share the wealth :)
I will update this top post with all the good info so its easy for everybody to find.
Try to not post mates rates prices as not everyone can get mates rates.
Try to keep the same format as this and if you know of a better price for the same part speak up and let everyone know, as a group we can use our buying power to buy specific parts off certain suppliers and maintain the cheap prices. Ausrotary has a good deal with VPW where they get a good discount on many products, if this works we could have the same arrangement though other suppliers.
Template
Part:
Part Number:
Brand:
Price:
Contact :
Now if you are looking for a Price on something that is not up here post
Price Check
Part Description/number:
so eventually everyone can track down the best prices from retailers
The Official Parts List
Part: G161z Main Bearings
Part Number:
Brand: Precision
Price: $59.95
Contact: VPW (paul) 1300659904
Part: G161z rod bearings
Part Number:
Brand: Precision
Price: $29.95
Contact : VPW (paul) 1300659904
Part: G161/180 Full Gasket set
Part Number:
Brand: Precision
Price: $99.95
Contact : VPW
Part: Thrust Washers
Part Number:
Brand: Precision
Price: $9.95
Contact : VPW
Part: Double Row Timing Chain Kit
Part Number:
Brand: Rollmaster
Price: $132.95
Contact : VPW
Part: G200z Timing Chain Tensioner
Part Number: CT54
Brand:
Price: $58.00
Contact : Bursons autoparts
Part: 4ZE1 Valves 44mm intake 37mm exhaust, biggest you can fit in a gemini head
Part Number:
Brand:
Price: intake $11.00 each / Exhaust $13.20 each
Contact : Reflex Engineering Shawn 039305 4840
Part: Crow Heavy duty Valve springs
Part Number:
Brand: Crow
Price: $88.00
Contact : VPW
Part: TF-TG Master Cylinder Rebuild Kit
Part Number: 7862
Brand:
Price: $30.00
Contact : Sunbury Brakes 03 9744 3438
Part: G200Z oil pumps (flow 16% more than a G161/180 setup
Part Number:
Brand: JIS engine
Price: ~$85.00 delivered
Contact : JIS Engine Inc
Part: Upper Ball Joint
Part Number: BJ118
Brand: PowerMax
Price: $22.00
Contact : Autobarn
Part: Lower Ball Joint
Part Number: BJ117
Brand: PowerMax
Price: $22.00
Contact : Autobarn
Part: Nolathane Bush Kit for a Gemini
Part Number: EVOGEM1
Brand: Nolathane
Price: $339.00
Contact : Autobarn
Part: Exedy/Daiken Heavy Duty Clutch (one step up from standard)
Part Number: GMK-6022HD
Brand: Exedy/Daiken
Price: $169.00
Contact : Autobarn
Part: Spigot Bearing for a Manual. Goes in the end of the crank shaft
Part Number: 6203 2RS V2 C3
Brand: HCH
Price: $8.00
Contact : Bearing Wholesalers, www.bearingwholesalers.com.au, 97479305 (melton store)
Part: Manual Transmission (4&5 speed) rear oil seal
Part Number: 97101
Brand: Kelpro
Price: $7.00
Contact : Melton Motor spares 0397433355 also available at autobahn for about $9.00
Part: Tie Rod End, Same part for both sides
Part Number: TE491R
Brand: PowerMax
Price: $17.50 (supercheap auto has them on special usually for as low as $10.80)
Contact : Autobarn/SuperCheap Auto
Part: Fan Belt
Part Number: 13A0875
Brand: Bosch
Price: $8.00
Contact : Autobarn/SuperCheap Auto/repco
Wfc
Post by Wfc »
Price Check
Part Description/number: Nolathane EVOGEM1 complete bush kit
Im looking for a retailer who does a good price on this or something similar
Wfc
Post by Wfc »
if you are looking for cheap Isuzu gaskets etc, check out this place i have been doing business with for a while now.
JIS Japan Engine Inc
http://www.jisengine.com/index.htm
They are based in the USA so shipping costs a bit BUT prices generally still come in cheaper than you can get it from over here.
They sell a lot of stuff direct though Ebay under the User Name of autoengpart http://stores.ebay.com.au/JIS-Engine
The good thing is that they do stuff for all ISUZU engines!
G180Z full Gasket Kit (same as G161z)
http://cgi.ebay.com/ebaymotors/ISUZU-IM ... QQtcZphoto
G200z Full Gasket Set
http://cgi.ebay.com/ebaymotors/ISUZU-PI ... QQtcZphoto
G200z Oil Pump (flows 16% more than a G161/180 item
these you can have landed for about $85.00, got 2 myself for that price
Wfc
Post by Wfc »
I have also priced up a set of 4ze1 valves delivered from JIS and they dont come in any cheaper then getting it from Reflex engineering
Wfc
Post by Wfc »
Brand: Nolathane
Price: $339.00
Contact : Autobarn
I would expect that there must be a supplier out there that is cheaper than this?
Wfc
Post by Wfc »
Part Number: BJ118
Brand:
Price: $22.00
Contact : Autobarn
Part Number: BJ117
Brand:
Price: $22.00
Contact : Autobarn
Wfc
Post by Wfc »
Brand: Exedy/Daiken
Price: $169.00
Contact : Autobarn
This Clutch apparently has 44% more clamping pressure than a standard one and is good for modified engines where you dont want to have a brass button clutch
Wfc
Post by Wfc »
Brand: HCH
Price: $8.00
Wfc
Post by Wfc »
Part Number: 97101
Brand: Kelpro
Price: $7.00
archangel62
Post by archangel62 »
G180Z rod big end bearings - apparently the same as G161Z
By ACL
CB-1032GP R171H
$39.95 I think it was
Autobarn
G180Z crank main bearings - apparently the same as G161Z
By ACL
MS-1103GP M171H
$79.95 I think it was ($120 total for both bearing sets)
Autobarn
G161Z copper 1.6mm head gasket (available in 1mm and 1.6mm)
By ACL
BC220CU16-GTR
$200, was told RRP was $300, however have since been told it should RRP at $130 odd and that it doesn't suit properly anyway because water holes are missing.
Note that copper head gaskets can be made by Copper Gaskets in Burton (SA) for $160-$180 or by Chris Milton Engines for $180-$200.
G161Z sump gasket, part # unknown
$18 I think at Autobarn, or like $7.95 at Sprint auto parts Mt Barker, but I was lazy and got it at Autobarn lol
Wfc
Post by Wfc »
Part Number: TE491R
Brand: PowerMax
Wfc
Post by Wfc »
Part: Fan Belt
Brand: Bosch
Price: $8.00
SHEEL
Post by SHEEL »
Shelliegem wrote:Recently investigated moulded carpet for a TG.
Cheapa Auto Spares at Oxenford (Gold Coast QLD)
(07) 5529 8999
Moulded Carpet in Black Cut Pile $175.00
Underlay $25
This seems to be only at their Oxenford branch. Carpet comes with cut lines marked out for shifter etc. Requires self install obviously.
Rare spares quoted $187.00 just for the carpet and that didn't include GST, delivery costs or underlay.
OGR88 GEMINI
Post by OGR88 GEMINI »
g200 rering kit includes rings all bearings and gaskets for rebuild
repco was around $400+
bursons auto $285.20
garmax $ 245
Garmax International P/L
Contact
Address 2 Aldinga Street
Suburb BRENDALE
Postcode 4500
State QLD
Phone (07) 3881-1692
Fax (07) 3881-1845
hope this helps
vance
Shelliegem
Post by Shelliegem »
(07) 5529 8999
Underlay $25
I picked up the carpet on the weekend and got in just in time cause the price has now gone up. It's now $200 for the carpet and $49 for the underlay. You could get the underlay somewhere else cheaper i'm sure of it and maybe the carpet but $200 is still not too bad but rarespares come in cheaper now depending on what they charge for freight.
