I decided to compile a list of Gemini part numbers for easy reference, the list is not complete for every model and may not be accurate, I will add more when i get time at work.
Radiator Hoses for TX model, or motors without air pump.(Gates Hoses)
top hose: CH1102
bottom hose: CH1121
hose to manifold: CH1186
valve to heater hose: CH1187
heater to manifold: CH1190
inlet to manifold: CH1223
Radiator cap: CA 15100 or CA3216 (recovery type)
Thermostat: TT-180, or TT2000-180 (high flow)
Thermostat gasket: TT640
Water Pump (Power Max): W827
Ignition Part Numbers (Bosch)
points: GD 214
dizzy cap: GD 366
spark plugs: W7DC (Bosch), BP6ES (NGK), BPR6EXI (NGK Iridium)
condensor: GD209
rotor button: GD 527
Switches/Electrics
Starter motor: RUTS007
Alternator: RUTA405
Regulator: BVR821 (Bosch)
Flasher Unit: TX P122, TC TD TE P123, TF TG P1230
Oil pressure: TPS006
Brake light: TBS010
Oil cap: TOC501
Fuel cap: TFNL217 (locking), TFL217 (non-locking)
Wheel Bearings (Timken)
Front: 2775
Rear TX TC: 2742
TD ->:2769
Diesel: 3176
VL V8 rear wheel bearings:2985
Gemini Part Numbers
Gemini Part Numbers
#Turbocoupe75
- New Member
Input shaft part number : NSK 6208nr*c3 103
By reaper5054 at 2011-10-26
Thrust bearing : NSK24tk308b2 encs 211
or: GSB323
or: GSB323
