Heater fan not working!!
Forum for all the new members to ask all them questions we have heard before.
Flaming will not be tolerated... If the regulars don’t want to read noobie stuff then don’t open this forum.
robbbbo666
Post by robbbbo666 »
Ok when i was putting my engine back in i shorted out a positive for the alternator on the motor and i had the heater fan turned on full when i tried to turn it over soim guiessing i have fried something
anyone got any ideas??
ipulled the fan out and tested it and that works fine!
is there a heater resister somewhere i may have stuffed?
Fuse works fine i even swapped it over just incase so yer STUCK!
G180 TG Wagon
dbart1961
Post by dbart1961 »
Have you checked to see if the fan motor is getting power with the fan switch and ignition on?
Regards, Dave
robbbbo666
Well ingot car on and running and I turn the switch back and forth and nothing happens like I said I pulled positive plug put and connectedthat to the battery so fan works I'm guessing something in the switch or between the switch and the fan is gone not sure what though
G180 TG Wagon
Diesel TE
Re:
Post by Diesel TE »
robbbbo666 wrote:Well ingot car on and running and I turn the switch back and forth and nothing happens like I said I pulled positive plug put and connectedthat to the battery so fan works I'm guessing something in the switch or between the switch and the fan is gone not sure what though
thread mined.. facebook didn't give me the answer yet
did you fix this? and was it the fan resistor if so?
