S15 SR20det wiring into TE
Is there anyone out there that could give me a guide to wiring a s15 sr20 into a TE wagon. I roughly understand how to wire up a s13 but believe the s15 to be different. Any help would be much appreciated. Cheers
Re: S15 SR20det wiring into TE
Should realistically be the same.
Wire in the sensors as normal.
Setup all your power earths and ignition wires, fuel pumps and go.
There's no difference in how to wire any engine conversion in really.
Probably best to separate most of the non-essential stuff from an S15 and wire in the rest
Alternatively after market ecu
Tis correct for just about all. Its only retarded ecus that are tied to bems that are difficult really. Just pin all the wires and tape them with masking tape and write on it. Do one at a time and mark it off your diagram makes it hard to go wrongJonno wrote: Probably best to separate most of the non-essential stuff from an S15 and wire in the rest
Cheers for the reply guys. Looks like I'll pull the loom apart and give it a crack.
Cool!
Build thread also
Build thread also
