Crank bolt direction
Forum for all the new members to ask all them questions we have heard before.
Flaming will not be tolerated... If the regulars don’t want to read noobie stuff then don’t open this forum.
snickalls
Post by snickalls »
I’m sure it must be anticlockwise to remove but I just want to be super sure before putting the long pipe on my breaker bar and giving it heaps.
So, does the g161z crank bolt undo in an anticlockwise direction and any tricks out there for easy-ish removal?
Sent from my iPhone using Tapatalk
Re: Crank bolt direction
99.9999999% sure its anti clockwise to loosen, but can check later for you as it has been a while
snickalls
Post by snickalls »
That’s pretty damn sure! [emoji3]
cjcrow
Post by cjcrow »
Yep anti clockwise as sometimes to crack the bolt you rest a breaker bar on the chassis rail and crank the engine. Engine turns clockwise as looking at it, so bolt would undo in anti-clockwise direction.
snickalls
Post by snickalls »
Cheers, to you both. First thing sat morning I’m getting the pipe out and leaning anticlockwise on that bad boy.
moley
Post by moley »
There ain't too many that are left hand thread boys :)
snickalls
Post by snickalls »
Wouldnt have thought so but this bad boy was super tight. I had a very long pipe on my biggest 1/2 breaker bar and still had to lean on it hard!
So, yep anticlockwise and farewell yo breaker bar.
