Remote shifter conversion - taken from Hotgemini Cache.
KINGEM
Post by KINGEM »
That all depends on how much you like the gemini shfter being where it is
The remote shifter is good in the sense that it brings the gearknob back a few inches and makes it feel more like you're driving a commo or what not....and the gears do actually feel closer when shifting
To install one,the only mods you need to do,is to cut a rectangular section out of the top of your tunnel (it comes back about 100mm from the original manual cutout ) and thats about it
Is it reliable?...well i havent had any problems,nor have i heard about anyone else having them
If you want,most of the brass bushes and bearings a can be sourced and replaced to reco' the unit.Holden can still supply most of them,and others you may need to look around
If you wanted to change it back to orig',it is possible....although,you're gonna have to do something about the section that you had to cut out to install it
Hope i was of some help
Hitting the streets......once the workload stops!
yldgem
Post by yldgem »
WillsTG wrote:Hey just a couple of noob questions i guess,
If you can get your hands on one of these is it worth it and are they reliable?
And also if you install one can you change back to standard?
Cheers Will
If you want to change back, you can but there will be a hole in your tunnel.
WillsTG
Post by WillsTG »
Thanks for the help guys i might look into it a bit more
LSD - Locked Standard Diff
__________________________________________________________
Bushcreature
Post by Bushcreature »
G'Day, having trouble tracking down a remote shifter, the wreckers all want to know year/model rodeo before they will look/answer. Any idea as to what years/models that had the remote shifters fitted?
Thanks heaps in advance!
GEM-DEO
Post by GEM-DEO »
89 shape tf rodeo 2wd
Dylan - 25 - Gold Coast Qld
See You An Tea
Bushcreature
Christies Beach auto wreckers supplied me with one from a Rodeo (I don't know the year/model) that is the same as the Piazza style. No need to fit a spacer plate, it bolts straight up to top of box and the bolt holes at the shifter end line up with the 2 pressed marks in the trans tunnel. close to the hand brake but should be ok. Shifter is extremely short though, just 4" including knob!
Thanks for your info anyway!
BC.
