oh thank god, this is the solution to my problem ive been having!
Thanks bro
peace out
Gemini Manual Gearbox Wiring FINALLY EXPLAINED!!
where have you checked for "the right volts?" if you have checked at the lights and found voltage then yes either your bulbs are blown or u have a bad earth on them. If you checked voltage accross the switch then in one position there would be power and the other their should be ( because the switch has shorted it out).Jem 12at wrote:Hey i just wired in the reverse lights on my TD wagon, the switch is working on the gearbox, the wiring is properly joined, im getting the right volts, but i still dont have lights. Ive just hooked up to the 2 red wires, is there anything else I should check, anything I couldve missed, except the unlikelyness that both reverse light bulbs have managed to blow?
I need more info..
Boostin for lyfe!
