DIY locked diff
Why would you spend $100 when you can make your own mini spool for a bit of gas and come wire.......
CHRIS...
CHRIS...
post contents removed
personal experience has me loving my locker on the freeway the car sits perfectly on the road and feel stable and strong. around big sweeping corners you cannot tell its locked and its only at slow speed on big corners that its harder to steer and it makes the jumping squealing noise. I love my locker and I believe my car would be extremely dangerous to drive without it. Personal opinion only. YES ITS ILLIGAL
Boostin for lyfe!
i just took the cover plate off, drained the oil completely.
degreased it all.
welded the s*#t out of it lol
greased the bearings and crown wheel, cover back on and filled the oil up and its been sweet as a nut for 6 months!
only took half hour too!
degreased it all.
2L DOHC 1976 TX Gemini HILLS
DATSUN 1200 Sedan MINT DAILY
Bluebird TRX CA18DET COILOVERS - DRIFTER
Yeah, I agree, it's the best way.
Heaps less breakages. Even better if you cut 'teeth' into the plate, so as it slots into the gears. Adds a shitload of strength. Make a cardboard template first..
You MUST remove bearings first. They arc internally, pitting the casing. I've killed a few diffs because I didn't remove them. They chew out, mashing the crown and pinion to death. Pre-heat the centre with ya oven/bbq/oxy...Microwave??
This one was for the Super Carry. Best mod possible for driving on 2 wheels..tipping over. Sorry, I have no before shots of the plate..
Cheers, Greg.
Cheers, Greg.
Look kids! It's an internet forum!
we welded one in car and it broke the welds after a few weeks took it out and welded theshit out of it so we will see how long it lasts nowTurbocoupe75 wrote:Take the gear carrier out before you weld it and degrease it properly, I have seen a couple of "In diff" locking jobs and after a few weeks they turn ugly with bearing noises ect ect. It may be quicker in the short term but do it once, do it properly.
