View previous topic :: View next topic  |
| Author |
Message |
Gene FJ20DEBT Supreme Overlord
Posted: Wed Sep 20, 2006 3:36 pm Post subject: Progress pics of fiberglass sub box |
| Code: | | Just put this here cos i needed to host all the pics in order for someone to look at from another forum as there forum dosnt alow excesive pics |
mould of the rear fire wall
out lines
trimed to shape
building the frame up of the fiber glass base
inside the amp rack is trimmed up now in black vynil....
cooling fans
[/quote]
lighting for the amp rack
[/quote]
remote wire froom the head unit is wired to a relay.. relay turns on the 2 cooling fans the LEDs and the amp...
led is on constant when ever the head unit is turned on
this is the access hole so that all the dials on the amp can be adjusted with out having toremove the amp to do so..
this end will be covered with a cover trim to hid the hole ... it will have 2 small grils also over each of the fans for cooling
heres a shot of the 2 bolts i fibber glassed in with big 40x40 washers to hold the install to the floor
all the wiring going into the amp rack
heres where i have stetched blue fleece over the whole fram3 and painted on as much resin as possible
[/quote]
after it had set i cut a hole in the back of the encloses and lined the inside of the section that houses the subwoofer with 4 layers of matting then sealed up the access hole with 2-3 layers from the inside
 _________________ "When you are a man, sometimes you wear stretchy pants in your room. Its for fun." |
| Back to top |
Boosted TG Long Term Member
Posted: Wed Sep 20, 2006 5:27 pm Post subject: |
Sh#t did u make that gene?? looks good as should make one up for a gemini  |
| Back to top |
Posted: Wed Sep 20, 2006 6:55 pm Post subject: |
lol give me a gemini and some money and ill do what ever u need  _________________ "When you are a man, sometimes you wear stretchy pants in your room. Its for fun." |
| Back to top |
Posted: Wed Sep 20, 2006 7:42 pm Post subject: |
so u havent done this to a gem b4 see how things go just got a new engine and getting it painted soon then a few things . . if im down ur way and got spare cash i'll let ya know |
| Back to top |
Posted: Mon Oct 02, 2006 5:09 pm Post subject: |
nope havnt done any big fiberglassing in a gemini cos i havnt owned one for 5 years  _________________ "When you are a man, sometimes you wear stretchy pants in your room. Its for fun." |
| Back to top |
gemhead Long Term Member
Posted: Fri Nov 03, 2006 2:12 pm Post subject: |
gene can i ask what is the advantage of having the fiberglass backing is it jsut to make it fit better or to give you the maximum box volume _________________
| Back to top |
Bradlze Long Term Member
Posted: Fri Nov 03, 2006 3:27 pm Post subject: |
| i would be thinking so it moulds to the floor properly so it doesnt move around so much |
| Back to top |
Posted: Fri Nov 03, 2006 3:29 pm Post subject: |
gene how do you attach the wooden frame to the fibrglass?
and did you cut the wood pefectly to attach to the fibreglass base? (around teh curves) |
| Back to top |
Posted: Fri Nov 03, 2006 3:47 pm Post subject: |
| not only so it doesnt move around but to look good and if done properly the sound will be good aswel, but one question what about the spare tyre?? like how u gonna get it in and out with a full fibreglass boot?? |
| Back to top |
Posted: Fri Nov 03, 2006 5:47 pm Post subject: |
| gemhead wrote: | | gene can i ask what is the advantage of having the fiberglass backing is it jsut to make it fit better or to give you the maximum box volume |
better fit and to maximis the space avalable for internal volum.. but mainly for a better fit
| Bradlze wrote: | gene how do you attach the wooden frame to the fibrglass?
used card to make template of the curves in the glass then trasfered it onto the timber, cut it out.
used liquid nails and screws to attach them.. then when it was dry, i lined it all on the inside with more layers of glass
| Boosted TG wrote: | | not only so it doesnt move around but to look good and if done properly the sound will be good aswel, but one question what about the spare tyre?? like how u gonna get it in and out with a full fibreglass boot?? |
not sure what u mean?? its a ute.. the spair wheel us under the tray....
or are u talkin about my coupe??
if so, i got that cover
| Back to top |
Posted: Fri Nov 03, 2006 6:46 pm Post subject: |
yeah i meant that in a gem how hard was it to put wheel underneath car?? |
| Back to top |
one Long Term Member
Posted: Fri Nov 03, 2006 7:30 pm Post subject: |
| looks awesome gene, you have talent |
| Back to top |
Posted: Fri Nov 03, 2006 7:37 pm Post subject: |
dunno. the pannel shop did it _________________ "When you are a man, sometimes you wear stretchy pants in your room. Its for fun." |
| Back to top |
Posted: Fri Nov 03, 2006 8:52 pm Post subject: |
| Gene FJ20DET wrote: | | dunno. the pannel shop did it |
how much they charge you?? |
| Back to top |
Posted: Sat Nov 04, 2006 2:09 pm Post subject: |
duno.. was included with my total body mods, prep and paint job bill _________________ "When you are a man, sometimes you wear stretchy pants in your room. Its for fun." |
| Back to top |
