It is currently Wed Jan 22, 2020 7:09 am
Post new topic Reply to topic  [ 7 posts ]
 Post subject: Crank bolt direction
PostPosted: Tue Dec 05, 2017 4:44 am
I’m sure it must be anticlockwise to remove but I just want to be super sure before putting the long pipe on my breaker bar and giving it heaps.
So, does the g161z crank bolt undo in an anticlockwise direction and any tricks out there for easy-ish removal?
Sent from my iPhone using Tapatalk
 Post subject: Re: Crank bolt direction
PostPosted: Thu Dec 07, 2017 6:46 am
99.9999999% sure its anti clockwise to loosen, but can check later for you as it has been a while
PostPosted: Thu Dec 07, 2017 10:46 am
That’s pretty damn sure!
PostPosted: Fri Dec 08, 2017 10:51 am
Yep anti clockwise as sometimes to crack the bolt you rest a breaker bar on the chassis rail and crank the engine. Engine turns clockwise as looking at it, so bolt would undo in anti-clockwise direction.
PostPosted: Fri Dec 08, 2017 12:13 pm
Cheers, to you both. First thing sat morning I’m getting the pipe out and leaning anticlockwise on that bad boy.
PostPosted: Sun Dec 10, 2017 4:34 pm
There ain't too many that are left hand thread boys :)
PostPosted: Mon Dec 11, 2017 8:03 am
Wouldnt have thought so but this bad boy was super tight. I had a very long pipe on my biggest 1/2 breaker bar and still had to lean on it hard!
So, yep anticlockwise and farewell yo breaker bar.
