1978 Gemini TD/TX Sedan Gold Coast $5100
Area to post your for sale or wanted Cars
Please prefix topics with WTB: or FS:
geminilover3236
Post by geminilover3236 »
This is a car with character and a much loved one at that, unfortunately it is time for it to go to a new owner so it can continue on. I have personally put a lot of work and effort into getting it to the state it is in today. That includes engine, driveline and suspension. I set the car up as a daily driven weekender. The engine setup is proven and the tune is safe, setup to run on 98 octane, however if you reduce the timing a few degrees, you could run on regular. (I can do this for you)
Contact Details:
Sergei 0422 574 526
Engine Details:
G200Z with a G161Z head giving a high compression engine of about 11:1 (Put in 1000km ago)
- Ported head
- Heavy duty valve springs
- 30/70 Camshaft (lumpy idle, plenty of top end power)
- Regraphed dissy giving a steeper advance curve which in turn = more power
- Single Dellorto DHLA 40 Sidedraft carby
- Torana Radiator
- 12V Electronic Ignition
- 2" Exhaust system fed by 4-2-1 extractors
- Oil catch can with recycle into carby to meet emissions standards. (red can in photo)
- Cooling system filter to prevent a clogged radiator (See top hose in photo)
- Muffler unbolts and can bolt on a single hotdog instead.
Suspension Details:
- SuperPro bushes all around, the only thing that hasnt got new bushes is the steering rack which are good condition
- Lovells springs in the front
- Pedders springs in the rear
- Munroe gas shocks all around
- Lock spacers for extra steering lock
Note: Standard springs come with the car and I can fit them at your request.
Driveline details:
- 13x7 Hotwires fitted with 155/65R13 tyres
- Locked diff, can supply and fit an open centre if required.
Additional:
- Deep dish small steering wheel
- Tacho fitted dash
- Secondary cigarette lighter
- Custom parcel shelf
- Stereo with 6x9s on the rear shelf + 5" in the doors
- Radio hidden in glovebox, original one still in place
- Auxilary cable run to drivers side phone holder
- Custom roof basket
- Drivers side rain guard
Can come with a lot of spare parts if required, just ask.
Open diff centre + standard height springs are included.
Might be able to organise roadworthy at your expense otherwise get a day permit and drive it home.
Last edited by geminilover3236 on Fri Jul 12, 2013 12:10 am, edited 4 times in total.
fat_tx
Re: 1978 Gemini TD/TX Sedan Gold Coast $5500
Post by fat_tx »
Must admit I was hoping to see a turbo carb application on this yellow rig!! Sad face
Anthony_Gemini
Post by Anthony_Gemini »
Sorry abit off topic , what spring & shock heights are you running ? That's on it's ass ,,,
Free bump anyway
geminilover3236
It's a combination of the lowest lovells in the front you can get and the lowest pedders you can get in the rear.
They are then chopped a couple coils (there abouts) and the bump stops in the front are smaller ones as well to allow travel.
Being the later model "squishy" bump stops, you still have quite a bit of travel after you hit them.
All in all its setup so that there is just enough travel and tyres don't touch guards ever.
Stig
Post by Stig »
Definitely one of my favorite Gems. Wheel and low combination is spot on.
geminilover3236
Thanks guys, bump..
ten20
Post by ten20 »
They square measure then sliced some coils (there abouts) and therefore the bump stops within the front are smaller ones yet to permit travel.
Being the later model "squishy" bump stops, you continue to have quite little bit of travel once you hit them... :shock:
2013 MERCEDES BENZ SL-CLASS
geminilover3236
I take it you are the guy who txt me.
There suspension travel in the front is about 10mm before bump stops and maybe a few more mm of compression on the bump stops.
Rear suspension travel is probably about 15mm all up. Also being the latter model "squishy" bump stops as opposed to the hard bump stops (which you will know about when you hit them)
Every modifications to the suspension has been done to ensure that wheels do not touch the guards at any stage.
And as mentioned, I am more than happy to fit standard height springs.
geminilover3236
Bump
geminilover3236
Re: 1978 Gemini TD/TX Sedan Gold Coast $5100
bump
