Gemini Sprint
- LOK15
- Gemini Master
Gemini Sprint
Started this a little while ago , now im getting stuck into it to have it finished for next years nationals
Cant really go into it too much , apart from it'll be green and should look awesome!
- LOK15
- Gemini Master
Re: Gemini Sprint
actually , its a custom mix. There is no clear in the engine bay. will be staying that way.
- LOK15
- Gemini Master
Re: Gemini Sprint
Started fitting the front flares , had to remove the original mounts as they werent compatible at all , makig up new bolts more suited to the body atm.
Re: Gemini Sprint
Sweet to see you doing one too look wicked in that colour
- Holden202T
Re: Gemini Sprint
barely finished one car onto the next!!
I like the blue, used to have a torana that colour, the green will certainly stand out more!
- LOK15
- Gemini Master
Re: Gemini Sprint
The V8 is a work in progress.. few mechanicals that im awaiting parts for , so this is happening in the meantime.202Gem wrote:barely finished one car onto the next!!
Re: Gemini Sprint
they are some big ass looking flares mon!
Re: Gemini Sprint
I agree. Do more to v8 gem.202Gem wrote:barely finished one car onto the next!!
Your as bad as me.
- LOK15
- Gemini Master
Re: Gemini Sprint
I have the brake upgrade bits , fuel flap hinges , this one and the V8 gem on the go atm, dont have time to stay specifically on one job.Jonno wrote:I agree. Do more to v8 gem.
Your as bad as me.
- LOK15
- Gemini Master
Re: Gemini Sprint
Mounting brackets made , now to cut off the existing ones and set these up to be glassed on , on the weekend.
Might have made too many , but can always use them on my CDT
- LOK15
- Gemini Master
Re: Gemini Sprint
started prefitting the rear flare , its going to need a little support at the bottom of the rear section as the curve isnt right.
Hoping on the weekend to have the new mounts glassed onto all the flares so whe i get around to the passenger side it'll be a little quicker to fit them up.
- LOK15
- Gemini Master
Re: Gemini Sprint
Flares arent a very good fit. rear 1/4 has a bad twist in it , have to put 2 supports on the base to get it back into correct shape.
Sanding of the boot spoiler has shown me it came from a red sprint , which went white , then yellow. Its back to its original blue gelcoat now.
- LOK15
- Gemini Master
Re: Gemini Sprint
Holiday progress
Have all but the boot spoiler ready to glass on the mounts and get right into the bodywork.
- LOK15
- Gemini Master
Re: Gemini Sprint
