Ozgemini Dyno Results Thread
Believe it or not a stock gemmi 4 speed, it has lasted for 10,000kms with 196rwkw with 2 trips to the drags and 600kms so far with 5 passes at heathcote. 2nd syncro is not so good but no other probs.Congrats mate, well done.
What gearbox have you got behind that?
I have a MUA rodeo box to go in hopefully soonish, I am keen to find the power limit of it. Hopefully it is as strong as I am expecting.
G180 252Rwkw on 26psi with GT3082
126Mph on pump fuel
126Mph on pump fuel
My gemmy only made 64.6HP when dyno'd the other day it has a g200 N/A with unknown head and cam spec's with elec dizzy and weber. I was quite dissappointed with this even tho it is over standard it came to my attention the guy who i bought the motor off when he built it has stuffed up the oil pump drive cog teeth causing the dizzy to be stuck on 0 degree's and not able to advance to even 6 degree's standard. Will post pic's of dyno sheet up soon. This power run was done with 19inch wheels so next time with the problems fixed she should be pullin higher numbers
Dyls
Dyls
I Like Biscuits and I like cheese, I keep them in the poket of my favourite jeans...
My G180 only got 65.7rw hp (49kw) and 233.8nm torque. It is a G180 bored 60 thou. Dished pistons. Electronic dizzie. TX head.25/65 cam. 32/36 weber and tuned extractors. I am not real happy with the result but the car seems to go just fine. Probably as the torque is quite high. Can't put the sheet up as it is a PDF and imageshack wont allow it. How do I convert it?
Regards, Dave
you relise you woulda made more power with like 15's instead of 19's?Brazzo_tg wrote:My gemmy only made 64.6HP when dyno'd the other day it has a g200 N/A with unknown head and cam spec's with elec dizzy and weber. I was quite dissappointed with this even tho it is over standard it came to my attention the guy who i bought the motor off when he built it has stuffed up the oil pump drive cog teeth causing the dizzy to be stuck on 0 degree's and not able to advance to even 6 degree's standard. Will post pic's of dyno sheet up soon. This power run was done with 19inch wheels so next time with the problems fixed she should be pullin higher numbers
Dyls
ve ss wagon i did a edit on had 22" wheels i put 19 ve sv6 wheels had in the corner at work at made 52rwhp more.
t3/t4 haltech powered forged 4ze1 gemini in the build
Yes I know but I didnt have any 15's or even 13's around as I live in wagga for uni but all my gemmy stuff is 2hrs away and I wasnt gunna drive that way to just get 2 tyres. Will be going on the dyno in the next few weeks again with 13's to see what it does pull before I rip it out for a lengthy overhaul of the whole car.lukes_tg wrote:you relise you woulda made more power with like 15's instead of 19's?Brazzo_tg wrote:My gemmy only made 64.6HP when dyno'd the other day it has a g200 N/A with unknown head and cam spec's with elec dizzy and weber. I was quite dissappointed with this even tho it is over standard it came to my attention the guy who i bought the motor off when he built it has stuffed up the oil pump drive cog teeth causing the dizzy to be stuck on 0 degree's and not able to advance to even 6 degree's standard. Will post pic's of dyno sheet up soon. This power run was done with 19inch wheels so next time with the problems fixed she should be pullin higher numbers
Dyls
The TX drag car (gemracing built) G180 EFI turbo made 241.6kw on 26psi
below is the youtube link of the dyno video
http://www.youtube.com/watch?v=7fymZaPkYdU
Cam
Cam
** 1983 ZZ/Z Gemini
** 1975 TX Gemini coupe
**Gem Racing TX Drag Car 347rwkw G180 EFI Intercooled Turbo plus Nitros built for 8's
