All good have figured out the h/b light issue. The old negative switching. Chrisco told me how it works. As for the charging warning light i tried switching the terminals around on alternator side but was still the same. Yep followed the write up to a tee. Def works as charging is pristine now. All good its not a major issue.F3ARED wrote:What model/dash? Wiring looms are different between all the models - ive got most of the manuals at home so can have a quick flick through and see what colour its meant to be. As for the charge light, sounds like you've made an oopsy in the wiring - did you follow the write up in the tech bit?
On another note, chasing a td cigarette lighter and assembly if you have one that works? Chrisco gave me one but it doesn't work unfortunately. Cheers mannnng
