So yeah that's the problem I'm having
I see lots of standard manifolds getting into gems so yeah what's the go?
They sit high low to one side? What's the go!
Any help would be awesome
Sr20 intake hitting brake booster
I come across same issue. Like you, I also saw a lot of std manifolds with std brakes and it fitted? Mind you, they were late model and mine was early. They also didn't have to mess with sump.
I went custom brakes. Found the smallest booster I could and went from there. Datto 120y are small and almost work with s13 master.
Then work out best placement of motor and brakes to get it to fit. Mine is not perfectly straight.
Good luck. Happy to answer any questions.
Cheers, matt
Cheers, matt
