304 to gem
General Gemini Chat
Forum for all gemini based chat & questions
Gene FJ20DEBT
304 to gem
Post by Gene FJ20DEBT »
- anyone done it?
- are the sumps a front or rear sump?
- Stock Sump fit in a gem as is? or need modifying?
redzone (coxy)
Re: 304 to gem
Post by redzone (coxy) »
Lol, can't believe you're posting this!
They are front sump, you need a hq sump for a gem.
Gene FJ20DEBT
Re: 304 to gem
yeah i was about to ask which of the early holdens had the rear sumps.
i goggle imaged for them but could get a good enough angle to see how the sumps were.
cheers maing.
Gene FJ20DEBT
Re: 304 to gem
same block/sump patern all the way to VT commo?
sly380
Re: 304 to gem
Post by sly380 »
Correct.
The sumps are cheap as s*#t off eBay but the oil pic ups are a little harder to come by.
what's the plan??
Here we go again😒
TURGEM
Re: 304 to gem
Post by TURGEM »
Gene FJ20DEBT wrote:same block/sump patern all the way to VT commo?
Yep.... Vt was the last of the aussie V8
Anthony_Gemini
Re: 304 to gem
Post by Anthony_Gemini »
Are early 308 carby blocks the same as the injected 304 blocks?
sly380
Re: 304 to gem
Post by sly380 »
Not really. Most parts are interchangeable but the blocks do vary on design.
Late vs series 2 to the end of production are hailed as the strongest and have the best oil delivery but I think alot of it is hype really
Here we go again😒
Gene FJ20DEBT
Re: 304 to gem
sly380 wrote:Correct.
what's the plan??
awsome.
im thinking if i find an SS cheap enough, for the drift gem, maybe swap it out with the D1.
cheers guys
Gene FJ20DEBT
Re: 304 to gem
or possibly the *puke* 3800.
i dont really wanna chop the car up much which i think the 5L will need
Anthony_Gemini
Re: 304 to gem
sly380 wrote:Not really. Most parts are interchangeable but the blocks do vary on design.
I didn't think they were the same ,, aren't the later model blocks 4 bolt
Re: 304 to gem
Why are you even contemplating a 5L?
Answer is clearly LS1 or 1uz. Grind weld skid
Gene FJ20DEBT
Re: 304 to gem
costs involved. 304 i could buy a whole SS that would have everything i need for less then what i could get just the LS engine on its own for.
1UZ would be fine, but again i could get a whole SS for the same price as a manual box and clutch to suit the 1UZ
3800 is looking more likely for easy of swap
Anthony_Gemini
Re: 304 to gem
What are you plans for it? Burnout car? IMO an old tired ss motor won't last ..
Gene FJ20DEBT
Re: 304 to gem
my drift car.
my old tired 4zd1 has lasted along time getting the s*#t flogged out of it.. so a lazy 5L should be fine
