Hi does any one have a base map for a wolf v4 ecu for 1.6 engine
or no any were i can get one thanks
Rob from wolf is not helpful at all
Wolf v4 ECU Base Map
Re: Wolf v4 ECU Base Map
Pm DR-GEM, he might be able to guide you in the right direction. You'll need to give him more engine details though like what crank trigger/distributor you are running, injectors etc
I should be able to give you something to help you out. send me a PM with some details. setting up the trigger is normally the hardest part.
I would have somewhere but to be honest be very careful with the v4 the timing jumps all over the show. I have run one in the liberty and the Gemini and they were both the same. Don't go overboard with the timing because it will jump up to 5degrees
