Acquired this from Facebook so thought I'd throw it up
Havnt seen it before
Body measurements
Re: Body measurements
Ahhhh so it was you who was asking lol
Is this a TX "Flat Floor" drawing?
Hope you can find a wagon one!!??
Yeah its a flat floor drawing. Having said that, its the same with the exception of the gearbox mount location/measurement.
Wagon rear suspension very different due to the lay over shocks.
Yes, the drawings are based on a sedan, so all the boot pan measurements will be different as well. Having said that though, the rest of the measurements ie crossmember to rear trailing arms, everything forward of rear seat pan, and crossmember to panhard rod should still be applicable.
haha yes! ive tried to get quotes to have mine jigged up before but nody can give me any amount not even a rough amount! thought if i can provide measurements then atleast all they would have to do is check it and then adjust itF3ARED wrote:Ahhhh so it was you who was asking lol
Reason theyll be reluctant to do that is even knowing how long/short you are in any given direction, theres no guaranty on how long it will take to pull back into place. Has to do with how badly out it is, how forceful the impact was etc. Say for example two cars, both are 10mm short - one was in an accident at 10kmh that resulted in that damage, the other at 40kmh. The higher speed shunt was obviously a lot more forceful, so even though they may have bent the same amount, it would take a lot more force to pull that 10mm back on the second example. Oversimplified, but you get the gist.
Ive had it done twice [once hidden damage early in the cars life, once my own fault because i am a dickhead] and it didnt cost me huge amounts, but this keeps in mind that i knew the guys doing it - the more recent one was done as a huge favour.
If your in the geelong area i might be able to help you out/can ask someone i know down that way. It wont be a Car-o-liner, but it wont need to be either. The old bolted-to-floor rack is just as good if the person operating it knows how to use it.
N-
N-
im aware thats its hard to judge but he couldnt even be like itll be between $xxx-$xxxx like obviously i know its a case of how long a piece of string haha
yeah i am in geelong actually!!
Was just checking. I know its in your profile but you couldve moved lol. Ill ask one of the guys i know down that way, hes pretty active in the muscle car clubs so he might know someone that can help
that would be great, cheers mate
