kizza
Posts: 628 Joined: Wed Aug 10, 2005 9:20 pm
Post
by kizza » Fri Feb 09, 2007 10:37 pm
Wfc wrote:
Part: G161/180 Full Gasket set
Part Number:
Brand: Precision
Price: $99.95
Contact : VPW
Part: G161/180 Full Gasket set (graphite head gasket)
Part Number: gc221g
Brand: Pro_torque
Price: $99.95 or $80.00 for non graphite
Contact :carbitz qld
vrs set quoted $55 from carbitz
Living Today
Posts: 295 Joined: Thu Oct 05, 2006 7:49 pm
Post
by Living Today » Thu Feb 15, 2007 7:36 pm
rubber rocker cover gaskets $12
bursons
lower ball joints $20
bursons
tie rod ends $15
bursons
Previously known as tx hotrod
tf s*#t box on the mend, but it's my daily.
F|sh
Posts: 2088 Joined: Mon May 16, 2005 11:13 pm
Post
by F|sh » Thu Feb 15, 2007 7:55 pm
Torque tube mount $157.50
loops
Posts: 61 Joined: Mon Sep 12, 2005 2:03 pm
Post
by loops » Fri Feb 16, 2007 5:57 pm
F|sh wrote: Torque tube mount $157.50
Where from? I got one from holden last year. It had to be found in NSW some where. No longer listed or made (OEM) I was told.
kizza
Post
by kizza » Sat Feb 24, 2007 12:36 am
zep
Posts: 1452 Joined: Tue Aug 16, 2005 4:31 pm
Post
by zep » Tue Feb 27, 2007 10:45 am
VPW Do not sell the Rollmaster kit for the G series engines anymore, just called them.
archangel62
Posts: 3667 Joined: Sat Aug 13, 2005 3:41 am
Post
by archangel62 » Wed Mar 07, 2007 2:53 am
Moly rings for G180W, including sending a piston off to Syd and back to have them measured up - and this was from a fairly expensive place... $195
These aren't parts but workshop work so people may want to know...
Copper head gasket made, block o-ringed, and some other labour... $400
Bores honed, new lower end bearings fitted, new rings fitted, and lower end assembled torqued adjusted etc professionally, includes some other labour... $1000
That work was done by Chris Milton engines.
Head faced, valves + valve gear taken apart and cleaned up, valves pressure tested, head ported, valve gear put back together, head chemically cleaned... $400
That was done by Don at S.A. Hills Engine Reconditioning
Posts: 2705 Joined: Wed Sep 28, 2005 11:55 pm
Post
by F3ARED » Thu Mar 08, 2007 4:02 pm
zep - i just ordered and picked up my rollmaster kit for the G series. They still do them, cost is 170.
Nick-
kizza
Post
by kizza » Sat Apr 14, 2007 8:57 pm
got a few more parts the other day so i thought id better put them up
Part: top radiator hose
Part Number: ch1102 or 94209303
Brand: mackay rubber
Price: $9.00
Contact: carbitz qld
Part: bottom radiator hose
Part Number: ch1121 or 94210290
Price: $9.50
Part: automatic transmition fluid titan atf 4000 5lt
Part Number: 2121005
Brand: fuchs
Price: $27.00
Part: gemini wheel stud
Part Number: ns343
Brand: ?
Price: $3.50 each
Part: cooler than normal thermostat 71c? instead of 82c? (160f not 180f)
Part Number: ttt-160 (normal one is ttt-180)
Brand: tridon
Price: $12.99
Contact: supercheap qld
kizza
Post
by kizza » Sun Apr 15, 2007 2:36 pm
found a receipt from a few weeks ago
Part: gemini welch plug brass 35mm
Part Number: rbc35mm
Brand: ?
Price: $2.20
gemini eagle igniton lead set
8b070 $4.20
8b075 $4.40
8b085 $5.00
ab090 $5.00
8d035 coil lead $3.50
Part: standard gemini spark plug
Part Number: bp6es
Brand: ngk
Price: $3.00 each
Living Today
Post
by Living Today » Sun Apr 15, 2007 7:07 pm
ramflow air filter for 32/36 weber.
rf658s
$57
repco
thermostat housing
wo9g
$14 includes gasket
kilkenny castings.(brand)
supercheap.
OMGWTFLOL
Posts: 30 Joined: Sat May 12, 2007 12:24 pm
Post
by OMGWTFLOL » Sat May 12, 2007 12:49 pm
zep wrote: VPW Do not sell the Rollmaster kit for the G series engines anymore, just called them.
McBullshizer, i know for a fact they have them on the shelf
fat_tx
Posts: 41 Joined: Sat Apr 22, 2006 3:42 pm
Post
by fat_tx » Wed May 30, 2007 1:52 pm
jus bac to the moulded carpet.. knox auto carpet in sydney does it cheaper than both those price quotes on prev page.. google it, easy to find, im sure theyll post too.
kizza
Post
by kizza » Fri Jun 22, 2007 9:39 pm
Part: g161/g180 waterpump
Part Number: cp827
Brand: roadsafe
Price: $50
Part: g161/g180 vrs kit (graphite head gasket)
Part Number: dc220g
Brand: protorque
Price: $55
kizza
Post
by kizza » Fri Dec 26, 2008 11:31 pm
just a quick note upper balljoints are bj117
and lower are bj118
not the other way round
and if you buy them from repco they have a t at the start of the part number
bj117 ($58 at repco $32 at auto one)
