sniper007 wrote:http://www.rta.nsw.gov.au/registration/ ... 9_rev4.pdf
Page 2 says what you can do without notifying RTA -
"Minor changes to wheels
Wheels up to 26mm wider than the largest optional wheel recommended by the vehicle manufacturer for the
vehicle can be fitted without the need to notify the RTA.
The outside diameter of the wheel and tyre combination must be no more than 15mm over the largest diameter
wheel and tyre combination specified for the vehicle and not more than 15mm below the smallest diameter wheel"
Page 3 says what you can do with an engineer cert -
Vehicles built to comply with ADR 24 (after 1/1/1973 for passenger cars)
Note: 25mm increase in wheel track limit also applies
Allowable rim width increase above the widest optional
Unladen weight wheel available for the axle assembly used
Up to 800kg - 26mm (1inch)
801 - 1200kg - 39mm (1.5 inches)
1201kg & over - 51mm (2 inches)
bigger wheels for NSW
- New Member
Re: bigger wheels for NSW
Have a look on your tire placard in the glove box and add the info above?
Ash
Ash
