Rattly G200Z
Rattly G200Z
This is a quick video of my G200Z, It's a high compression engine 10:1, electronic ignition, 4-2-1 extractors, ported head, sidedraft dellorto 40 carbie.
http://youtu.be/Wd6Wf7j8w4E
It's a bit hard to tell in the video but it sounds overly rattly compared to other G-series I've had. Anyone got any ideas why and/or if it's an issue that I should be concerned about?
Cheers.
Cheers.
Try cam chain adjuster slide bent in the shape of a banana and all the teeth smoothed off the adjuster. Thats what happened to mine.
Although G200 adjusters are supposed to be prety good I had one that had the pawl and adjustment teeth rounded off so it would not lock. The chai actually broke the adjustment slider in half and chewed through the base of the guide on the fixed side and into the block.
Do not ignore the rattle or the chain will jump and bend valves or the chain will chew through the water jacket in the timing cover. Good chain and tensioner and lifters adjusted the G200Z is meant to be a pretty silent engine.
Easy to check.
Easy to check.
does this apply 2 the 1.6 also? noticed our other gem is a bit more rattlely than wat ive heard b4 also.tobytj wrote:Try cam chain adjuster slide bent in the shape of a banana and all the teeth smoothed off the adjuster. Thats what happened to mine.
Easy to check.
Thanks Toby,
I ran out and popped the rocker off and checked it and it was all fine. The chain was sitting centred, the tensioner all the way out and when you rotate the engine normal rotation it would stay tensioned, when you tried to rotate it the other way it would try to de-tension but is stopped by the teeth on the tensioner. There was still some movement though and the chain isn't REALLY tight but it isn't loose enough to jump a tooth.
Hope that makes sense.
It is a 1.6 head, if they are smaller (vertically) then this could be why there is some slight slack in the chain. Also the tensioner material that the chain rubs against could be worn down so isn't holding it out as much. The tensioner literally cannot go any further out though.
- LOK15
- Gemini Master
it does indeed sound like timing chain rattle , but im on a laptop with crap speakers. Could be excessive piston slap. We need a bit more history of the motor.. has it gradually made this niose , did it do this from the time you put it in and started it? , since doing a mod to the motor?
- New Member
The four key suspects here are tappets, timing chain, big end bearings, pistons. From your description of drifting and flogging big end bearings are shortening to second favorite.
Each problem has a specific noise signature.
Tappets - you can check and eliminate and the noise signature is intermittent tapping that does not vary with engine load just revs.
Chain - continuous steady rattle and still my odds on favorite to win
Big ends - rev the engine steadily and then back off. A big end rattle will be loudest as you back off.
Piston Slap - will be louder under load.
As said it sounds like a chain. if the adjuster is out all the way that puts lots of stress on the pivotted guide and and they bend - that's what happened to mine.
This is good idea, can be a big arse screwdriver (fits in ear well)...77tc_coupe wrote:Grab a peice of timber place it to your ear and then Place it on different areas of the engine and the timer will act as a stethoscope, you may be able to pin point where this noise is coming from using this method, therefore making it easier to find out what is wrong.
WASTEGATES - WASTE 8S
So I was thinking, seen as it's a G200Z with a 1600 head. doesnt that make the total height of the engine smaller than a standard G200Z. So the length from top cog to bottom cog for the timing chain would be shorter yes?
Would it be possible to fit a chain minus 1 link and would this fix it, i.e. making the chain tighter as the tensioner is fully out atm and cant physically go any further.
As Lok said it is a bit hard to tell over a computer. I had a G180 that was a bit rattly and everything looked fine. It still ran and performed great.
Turned out to be a cracked piston skirt.
The skirt hadn't broken completely but it was still enough to make a rattly noise. Even with the head off it was not obvious.
