Ozgemini Dyno Results Thread
General Gemini Chat
Forum for all gemini based chat & questions
OLDSCHOOL
Post by OLDSCHOOL »
HYP51 wrote:Hmmmm how much timing is in it? Just doesn't seem that alive yet :?
This motor with a manual behind it would be pushing close to 300wk at the wheels with this tune. The stall in it also chews up heaps of power.
HYP51
Post by HYP51 »
Its still around 40 hp down even with the auto atm.
gemracing
Post by gemracing »
Its got hardly any timing in it at all,Once Cam is use to the car it will get the timing and boost its built for......(and the nitrous)
Darren
Current Car.....
-G180 TX red coupe 9.20@148.6mph on a 26x8.5" tyre and no nitrous 2380lbs with driver
gemracing
Post by gemracing »
Unless you have a super tight converted,you'll always show lower hp on a dyno.......
Current Car.....
rotagem
Post by rotagem »
g200,injected,microtech,t04e/bb made 230rwkw on 20psi :D good fun. no dyno sheet need to get another one
gemracing
Post by gemracing »
Cam's G180
-United servo E85 (Not race E85)
-Precision turbo
-28psi
-Auto trans and Gemini rear end..
-Max power was at 8000rpm,Max torque was at 7800rpm
(Although this power should get this car into the 9's at approx 140mph,we will be putting at least another 10-15psi into the engine when it gets on the dyno next,this was also with NO NITROUS)
Current Car.....
STEVOOOish
Post by STEVOOOish »
stock SR20DET.
7psi
Standard Internals
Front Mount
By stevoooish at 2012-06-04
SR20DET TG 1984 (170rwkw grandpa car)
Matty's Injected
Post by Matty's Injected »
I also had a dyno with no printer :( But here's the figures anyway
NA G180 + 120' flattops
Rejetted Nikki carbie
4-1 Extractors 2.5" exhaust
87rwkw
Same NA G180 w/ Rodeo injection 72mm TB, VL injectors, Haltech F9 computer
97rwkw
Will be going to quadTB next, so will do another run then
Next project G180Z Quadthrottle EFI w/NOS (maybe)
hotgemi
Post by hotgemi »
CA18DET
GT2876R turbo
Microtech Lt10s
560cc injectors
Bosch coils
Just made 260.2hp At the wheels on 18psi
Pretty happy with that!
arrow
The Grand Master
Post by arrow »
Just come back from the dyno. G200 on 29PSI. 8000RPM. On Methonal.
redzone (coxy)
Post by redzone (coxy) »
f*#k yeah, congrats!
what rpm???
luke20
Post by luke20 »
arrow wrote:Just come back from the dyno. G200 on 29PSI. 8000RPM. On Methonal.
Its in the title coxy :wink:
I've joined the dark side.......... Toyota AE86.
Also bought my Gem back... awwwww shieeeetttt
GEMWRC
Post by GEMWRC »
haha Killer Arrow !!!!!!!!
OLDSCHOOL
Post by OLDSCHOOL »
awsome arrow. Any pics or details on the car?
TX Coupe. Isuzu G180, gemini auto and gemini diff. 10.84@127mph
TG Panel Van- G180
arrow
The Grand Master
Post by arrow »
The car is a td coup. it was dynoed with a manuel in it. i will post more details and pics in a new thread soon.
I was happy with numbers it made on the boost level. i feed the boost in slow as it is a G200. and we all know what g200s are like with head gaskets. the start of the run is just under 4000rpm and the top is 8000rpm
